4th gear speed in a W-30
dlp
04-06-2005 14:14:42
I"ve noticed the speeds in some IHC tractor data guides list the 4th gear speed in my "37 W-30 to be between 10 & 14 mph. Mine does not run this fast. My 4th gear speed is not a whole lot faster than 3rd. Does anyone know what it could be?
Sloroll
04-06-2005 14:34:47
 Re: 4th gear speed in a W-30 in reply to dlp, 04-06-2005 14:14:42
Did your W-30 come out on steel or pneumatics (Rubber)? The fast transmition was an option only on pneumatic equiped tractors. Look at your serial number. Is ther a P and a T in it? P for pneumatic and T for transmition.
dlp
04-06-2005 17:04:34
 Re: 4th gear speed in a W-30 in reply to Sloroll, 04-06-2005 14:34:47
That"s where it gets interesting. The tractor came out on steel. It has a P on the tag. The tractor spent it"s life on one farm, according to the man who owned it & I have no reason to doubt what he"s telling me.
Sloroll
04-07-2005 06:54:07
 Re: 4th gear speed in a W-30 in reply to dlp, 04-06-2005 17:04:34
Could be the dealer swapped em out. He may have had the tractor on his lot and someone wanted pneumatics.
pgo12
04-06-2005 17:55:17
it depends on the tag. p, pnuematic tires.... s, special features.... m, modified.... sp, four speed-15 mph on tractors below wb15106.... t, four speed-10 mph on tractors wb15106 and up..... ha, high altitude pistons..... sl,lower low gear..... h, differential lock..... d, distilate.... my w30 has a p for the pnuematic tires, four speed. fourth gear is about 3 mph. has a really low,lower gear, but no sl on my tag. who knows. . hope this helps. pg
