1949 Super A Carburetor
NCRick
04-06-2005 16:52:13
My Dad passed away recently and I"m trying to get his 1949 Super A ready for mowing. Started okay and drove around a couple times in the past week. I just put a new belt on mower and got that working. Tonight when I hand cranked to start the A, a little burst of fuel spouts from the carburetor, which is now also dripping fuel noticably. A mechanic friend took a quick look and he thinks carb will need to be rebuilt with a kit, or possibly new carb depending on costs. Dad had the engine rebuilt a couple years ago, but the tractor sat a lot since then. Anybody have a suggestion on whether I should look for a kit vs a new carb? I think there is a place nearby that Dad ordered parts from, but if you have suggestions on where to get that might help too.
ddg
04-06-2005 17:06:24
 Re: 1949 Super A Carburetor in reply to NCRick, 04-06-2005 16:52:13
The kits are pretty cheap at some of the farm & ranch stores or online. My 49 SA has a Zenith carb (I think) Real easy to take off & take apart. Try that first. Most of the time when mine starts running rough under load, it"s starving for fuel, It clogs up with crap where it drains out of the tank into the sediment bowl. I keep a piece of clear 1/2" hose rolled up under the seat. I shut it off, take the sediment bowl off, put one end of that hose up into the outlet, & blow into it until it gurgles back inside the tank. Usually good for a few more laps! I"ve tried cleaning that tank a dozen times, & it still gets stopped up.
NCRick
04-07-2005 13:23:03
 Re: 1949 Super A Carburetor in reply to ddg, 04-06-2005 17:06:24
Thanks for the info, much appreciated. I will pick up a kit and see how it goes. Also will look at cleaning the gas tank a bit.
El Toro
04-07-2005 07:11:26
Isn't there a process for relining those old gas tanks? I think I saw it posted on here sometime
ago. That would stop all that rusty crud from entering the fuel system. I use a tank vacuum
to remove the rust from a gas tank from my car.
The car had fuel injection and kept cutting out,
then would restart very easily. I silver soldered
a fiiting to the gas line and installed a gauge.
When you tried to accelerate up a hill the pressure would drop. I pulled the tank and the
fuel gauge and the pump assembly out. I had to get my wife to wipe out the tank, my paws were too big. That vaccum does a good job, do it outside. My tank vacuum is for wet or dry. I wouldn't use anything where the fumes may go through the motor. I replaced the pump too, my neighbor said I wouldn't change that pump. I answered him by saying. You're not changing the
pump and that's where the labor is. Hal
NCRick
04-07-2005 13:27:10
 Re: 1949 Super A Carburetor in reply to El Toro, 04-07-2005 07:11:26
I bet rusty crud is sure enough a factor. I'll try to see if I can help the tank any when I tackle the carb. Many thanks!
JOSSETTE
04-06-2005 17:02:28
you might just have a little junk in the tank and it went into the carb...
NCRick
04-07-2005 13:24:35
 Re: 1949 Super A Carburetor in reply to JOSSETTE, 04-06-2005 17:02:28
Thanks, I'll see if I can clean up the tank any.
