W6 Brake Adjustment
Yugrotcart
04-06-2005 18:15:22
I am trying to set up the brakes on my W6. Both brakes work well but the pedals are travelling too far.(Past the parking brake) The right side will adjust up, but the left has no more adjustment, bolt on the end of the spring. At rest the lever coming out of the brake cover on the right is at 3 oclock,horizontal, the left is at 8 oclock, past horizontal. Is there something else out of adjustment?
chadd
04-07-2005 05:13:37
 Re: W6 Brake Adjustment in reply to Yugrotcart, 04-06-2005 18:15:22
Are these new brakes or used brakes? If they are used, then my guess would be that the band is worn down too far to adjust any more. On the other hand, if these are new bands, something didn't get assembled right. If the bands are new, are they from a Case IH dealer or are they aftermarket? I have heard some bad things about aftermarket bands being the wrong length, so that there isn't enough adjustment to make them work. We had a similar problem with our W6, but it was because someone had broken the shaft that twists the band and welded at the wrong angle with respect to the shaft, so it was about 45 degrees off, not allowing it to tighten the band enough. Took quite a while to figure that one out. . .
