McCormick power 31 loader time cover return spring
Jim Perander
04-07-2005 06:05:25
I am looking for a time cover return spring for a McCormick power 31 loader. The part number is 650-552-R1. Thanks for any help
john in ohio
04-07-2005 17:21:36
 Re: McCormick power 31 loader time cover return sp in reply to Jim Perander, 04-07-2005 06:05:25
i use garage door springs on mine. the ones that are about 1 -1 1/2" diameter and about 2 1/2 foot or 3 foot long.
where are you located.
RustyFarmall
04-07-2005 07:09:33
That might be tough to find. Most of those return springs were removed because they were more of a nuisance than anything else. The spring would not allow the bucket to fully dump unless it was full of very heavy stuff, and then the spring would return the bucket so violently that it often would throw the remaining material back on top of the tractor, sometimes even into the operators face. I removed mine for this reason. Just drop the loader to the ground and drive backwards a bit and the bucket will latch back into place.
