424 fire order 1342- where is # 1?
blackdog
04-07-2005 17:47:16
A dumb question, for sure. Is #1 up in front next to radiator?. Meaningful replies much appreciated.
1256 puller
04-08-2005 03:36:58
 Re: 424 fire order 1342- where is # 1? in reply to blackdog, 04-07-2005 17:47:16
An easy way to make sure to make sure is to bring #1 up to top dead center on the compression stroke and see where the rotor is pointing.This should be at the factory location of #1 towards the radiator.However if someone has moved the distributor and the rotor is no longer at that position just plug in #1 wire to where the rotor is pointing now and continue wiring cap from there according to the firing order.This procedure will work on any gas engine no matter make,model,etc..
Dixieland
04-07-2005 18:06:35
That ain't a dumb question if'n you don't know but you are right, closest to the radiator.
blackdog
04-07-2005 17:56:43
Red Dave, thanks, my crap manual does not tell much.
Red Dave
04-07-2005 17:50:34
Yup. #1 is the one closest to the radiator.
