12 or 6 volt
ccr
04-07-2005 18:14:45
i have a 140 original charging system man i got tractor from is very sick had no battery it has a positive ground i know will run with 6 volt but seems to hard to start i run straight wire from batt to coil to crank was suppose to all be working could it be 12 how can i tell
PAULIH300
04-07-2005 18:21:43
 Re: 12 or 6 volt in reply to ccr, 04-07-2005 18:14:45
Put in the 6V battery,get it running,and then take a voltmeter to the battery.It should be charging at 7-8volts.Also,check the voltage regulator....they usually have stamped on them the voltage.
