Re: Should new brake bands squeal?
M 560
04-08-2005 05:53:20
use some kind of lubricant
EricB
04-08-2005 05:56:08
 Re: Should new brake bands squeal? in reply to M 560 , 04-08-2005 05:53:20
I am shocked. "oiling" (or lubricating) your brake surfaces is a sure fire way to the cemetary.
M 560
04-08-2005 06:10:28
 Re: Should new brake bands squeal? in reply to EricB, 04-08-2005 05:56:08
not if you use the right lubricant
janicholson
04-08-2005 08:50:41
 Re: Should new brake bands squeal? in reply to M 560, 04-08-2005 06:10:28
Break em in for a few months and it should stop. Never put any liquid material/lube on a lining or friction surface. Residue free (Brake Kleen) sprays, and laquer thinner for cleaning are exceptions. Drying the parts before assembly is important. I assume the "use some lube" comment was directed to the linkage issue mentioned in the original post.
