Hydrawlic pump for 300 u
earl in pa
04-08-2005 17:38:56
Does anybody know where I can buy a rebuilt pump for a 300 utility.
old
04-08-2005 19:38:52
 Re: Hydrawlic pump for 300 u in reply to earl in pa, 04-08-2005 17:38:56
This site and or value bilt
PAULIH300
04-08-2005 18:52:29
From what I gather,once the seal area on the shaft grooves up,no seal will ever live for long and even sleeving is no permanent solution (you still havent fixed the actual gear pumping part).I dont know what they have to replace when rebuilding,but if they have to replace the gears and the main shaft,that would only leave the original housing as the only vintage 1955 part.Thats gotta cost almost what a whole new one is going for.
It sorta reminds me of auto parts store rebuilt alternators,starters,water pumps,and power steering pumps(as well as wiper motors,smog pumps,fuel pumps...etc).....they never last as long as new (or the original),because you are starting off with old used component parts already.
David A. Hodson
04-08-2005 18:34:45
if you got a hydraulic repair shop near you they might be able to rebuild your's Good Luck David
PAULIH300
04-08-2005 17:49:36
You're probably better off with a new one.They are available from most IH/Farmall online sources.
Aint cheap,but just think....it will last for another 50 years....
