Order Farmall Cub Parts Online
cub carb problem
jerry red cub
04-10-2005 05:24:48
tracter runs and starts fine,but when put under aload it dies unless you run it half choked.the only adjustment screw is turned the hole way in,and if you try to back it out the engine dies
Rudi
04-10-2005 08:21:58
 Re: cub carb problem in reply to jerry red cub, 04-10-2005 05:24:48
third party image
Jerry:
The simplest way to attack this problem is for you to cut and paste the url for the Cub Manual Server below into your browser. Once there go to the Maintenance Tips and Techniques link, then to the Lurker Carl's Carb Fixes.
Read that. Then read the Blue Ribbon Service Manuals.
You might be lucky and just have a carb adjustment problem, you might need a carb rebuild or you may need one of the above plus some tweaking of your governor.
You might also want to read the Best of H.L. Chauvin whilst you are at the server.
Hope this helps
