H air cleaner removal
Kent in NB
04-10-2005 05:56:42
How do you manuever a wrench to reach the head of the lower bolt. It does not appear accessible, without taking off gas tanks and steering shafts. Of course, the bolt is just loose enough to turn. All I want to do is remove and flush the cleaner. Thanks, Kent.
John in Ct
04-10-2005 18:53:28
 Re: H air cleaner removal in reply to Kent in NB, 04-10-2005 05:56:42
I had mine off the other day. It can be done by one man but it is MUCH easier with 2. Take the hood off. On the carb side, use a socket with extension (can't remember if we used a flex or not because I was on the other side with a regular Snap-On combination wrench). I used the open end side of the wrench. The only problem you may have will be that you can't get the wrench on the nut because of the nuts position. No problem, hold your open end wrench against the nut, have your helper turn from the other end(off direction). The bolt and nut will turn together. When the right angle is reached, your wrench will just slip onto the nut and your helper can unscrew it. I hope this helps.
SGT K
04-10-2005 06:42:22
If I remember right, I used a long 45 degree wobble extension. I remember it being sort of a pain because I shimmed mine out with a flat washer to make my pipe come out through the center of the hole in the hood.
My e-mail is open if you still have trouble, I'll look at mine tonight when I get home.
Good Luck
Paul
Kent in NB
04-10-2005 16:22:10
 Re: H air cleaner removal in reply to SGT K, 04-10-2005 06:42:22
Thanks SGT K. What path do you have to get inside the support column? I don't really see a hole to get in there.
