farmall 400 3 pt. fit on m
tim bynum
04-10-2005 15:33:43
can someone tell me if a three point hitch off a farmall 400 will fit on my farmall m. thanks, tim
randy hall
04-10-2005 18:14:45
 Re: farmall 400 3 pt. fit on m in reply to tim bynum, 04-10-2005 15:33:43
i have a saginaw three point hitch that i would sell that would fit your m.
JOSSETTE
04-10-2005 18:23:55
 Re: farmall 400 3 pt. fit on m in reply to randy hall, 04-10-2005 18:14:45
how much???
randy hall
04-10-2005 18:38:00
 Re: farmall 400 3 pt. fit on m in reply to JOSSETTE, 04-10-2005 18:23:55
$600 also includes new two spool valve so you can also use remote
CNKS
04-10-2005 16:59:47
400's did not come with factory 3 point. Basically the 3-point for an H or M will fit everything through the 560 series, possibly higher. So the answer is yes, as the spacings for attaching it to the rear axles are identical. In fact the spacing does not differ for the C,H,M,Super series, 400,450,460,560.
