gas in oil
rw1227
04-10-2005 17:55:56
does anyone know how or what the problem is if gas is leaking into the oil pan of a 300. thanks any info. is greatly apreciated
JOSSETTE
04-10-2005 18:15:49
 Re: gas in oil in reply to rw1227, 04-10-2005 17:55:56
since the carb sits below the head on the outside of the block you must have some damn good compression...
I would say___
weak spark plugs
coil
or its time for some rings...
PAULIH300
04-10-2005 18:07:20
Oil dillution by gasoline is mainly a case of cranking the engine for long periods without combustion (not starting).Also,could be excessive use of the choke,overflowing carburetor,plugged air filter,or bad piston ring seal.
Aces
04-10-2005 18:05:39
RW1227 You have a leak in the carburator. The float is stuck down not closing the needle valve or the needle just does not hold.
kjm
04-10-2005 19:01:04
 Re: gas in oil in reply to Aces, 04-10-2005 18:05:39
Aces is right,also check your air filter it is full of gas too.
