miss on a 707
Thresherman
04-10-2005 18:39:58
Got my 706 home yesterday. Did a tune-up, oil change. Had a miss comming off idle fast when I bought it, but figured the bad points were the cause. Now with new points and condenser it still does the same. All I see is an idle mixture adjustment, nothing for the high speed or anything. Could use all the help I can get. Thinking I might need to rebuild the carb.
Thanks for the help
Aces
04-11-2005 08:14:13
 Re: miss on a 707 in reply to Thresherman, 04-10-2005 18:39:58
Thresherman All there is on that carb is one air adjustment for idle, one for load out the dack and a stop screw on the cross shaft for idel speed. The 706 had a electric solenoid on the load screw the ealy ones could be adjusted the later ones could not and some been changed out to not solenoid.
El Toro
04-11-2005 08:12:34
Have the sparkplugs been replaced lately? I would do a compression check to see how close the readings are. May have valve not seating very well. Hal
