RUST!
BigTex
04-11-2005 09:16:21
I found an old 2 bottom disc plow on my property a couple of years ago. I'd like to use it except the steel bars that are suppose to rotate to allow it to drop for plowing are frozen with rust. Was is the best way to get these bars to break loose?
RayA
04-11-2005 15:28:51
 Re: RUST! in reply to BigTex, 04-11-2005 09:16:21
you might try spraying with penetrating oil once or twice a day for awhile and giving it a couple raps with a hammer to try to loosen things up. Heating with a torch might help to loosen it some also. Good luck. RayA
