McCormick Grain Drill Gears
D.A.R.
04-11-2005 17:33:09
I have a McCormick 16 x 7 M.D.R.F. drill and i need to get two eight tooth gears so i can plant beans with it. i already have the 16 tooth gears i just need the 8. does anyone have two they can sell me or know where i can get them. thanks. also need 2 steel tubes and 1 set of drag chains.
MagMan
04-12-2005 05:22:43
 Re: McCormick Grain Drill Gears in reply to D.A.R., 04-11-2005 17:33:09
Hey DaR, I have a complete Drill but I dont know what model it is and a whole bucket full of extra gears. Where are you located at.
DAR
04-12-2005 07:11:07
 Re: McCormick Grain Drill Gears in reply to MagMan, 04-12-2005 05:22:43
Northern ILLINOIS
MAGMAN
04-12-2005 07:17:27
 Re: McCormick Grain Drill Gears in reply to DAR, 04-12-2005 07:11:07
WELL I AM IN NY NOT TO FAR.If you tell me what to look for I will. JON
Michael Soldan
04-11-2005 20:16:53
DAR, my old McCormick drill needed new steel spouts and my local I-H dealer could only get rubber ones, they fit perfectly and come with a pre cut wire that clips around the top of the spout and snaps around the head of the drill opening, they are easy to install and never rust out, about 2/3 of my spouts are now rubber. Sorry I can't help you with the cogs but surely someone out there has some..good luck from Mike in Exeter Ontario
Haas
04-11-2005 18:01:39
Do you have a casting number off the gear you have?? I have several implement gears that I don't know what they fit. If you have the part number for the gear you want, or the one that you have now, I can take a look and see what I have.
Wratchet
04-11-2005 17:49:19
D.A.R. I don't think I have the parts book for the drill but if you could give me a casting number or parts ID I may be able to find the gear. I know I have some drill parts but have not brought them in to catalogue as of yet.
DAR
04-11-2005 19:06:35
 Re: McCormick Grain Drill Gears in reply to Wratchet, 04-11-2005 17:49:19
i will have to get the numbers in the morning when i go to the barn. ill post tommorrow. thanks
