986 clutch, ta, mcv
Brad Merck
04-11-2005 18:57:37
I just put a new clutch, pressure plate, flywheel, and front trans seals on my 986. Got it back together and with TA in high when I let out clutch it takes off and after about 1-2 seconds it acts like it takes off faster like its shifting into high in the TA. If I start in Low TA and shift into High it doesn"t do it. It is leaking hydraulic oil from the MCV. Do I need to rebuild the MCV, or does it sound like the TA is going out.
K.B.-826
04-11-2005 19:39:19
 Re: 986 clutch, ta, mcv in reply to Brad Merck, 04-11-2005 18:57:37
Adjust your linkages out, especially the dump valve.
Bernard le mécano
04-13-2005 16:24:08
 Re: 986 clutch, ta, mcv in reply to K.B.-826, 04-11-2005 19:39:19
Hi, adjust the dump valve rod for the TA light came off just before the tractor start to move. You have to re-adjust each time you adjust the clutch. Bernard le mécano
