difference between relay and regulator
AdamA
04-11-2005 19:01:33
I am restoring a Farmall MD. It has what appears to be a relay mounted near the radiator. I have to buy a new wiring harness for it. I can only find harnesses for tractors that have regulators mounted under the gas tank. I was wondering if I could change this tractor to have a regulator instead of a relay? Thanks for the help.
Bob M
04-11-2005 19:25:41
 Re: difference between relay and regulator in reply to AdamA, 04-11-2005 19:01:33
Adam - How many positions does the light switch have?
If it's got 4 positions the tractor was originally equipped with a cutout relay. But if there's only only 3 positions then it had voltage regulator - that relay by the radiator had to have been added for some other purpose.
Note also that cutout relays are almost always mounted directly on the generator.
AdamA
04-11-2005 19:52:56
 Re: difference between relay and regulator in reply to Bob M, 04-11-2005 19:25:41
Bob,
I would have to look at the light switch. I can't remember what it is for sure. The parts book shows a harness for a relay mounted near the radiator. I also have another MD with the relay mounted in the same place. Both of them look like they have factory harnesses.
PAULIH300
04-11-2005 19:03:47
Thats probably a cut out relay.It opens the circuit when the keyswitch is turned off.
JOn Blanc
04-12-2005 03:58:26
 Re: difference between relay and regulator in reply to PAULIH300, 04-11-2005 19:03:47
Did an MD have a keyswitch? I didn't know that! Jon
