240 U hydraulic pump
Al L. in Wisc.
04-11-2005 19:05:56
Hydraulic fluid goes through system and into crankcase like a seive, well not quite. When I purchased tractor, I checked engine oil and it was beyond being "topped off". Added hyd. fluid and system worked for a while, and now hydraulics won"t operate and crankcase is "fuller". Anyone have pros/cons on hydraulic pumps I see advertised on this site "Farmall/International hydraulic parts"? Thanks in advance
K.B.-826
04-11-2005 19:34:22
 Re: 240 U hydraulic pump in reply to Al L. in Wisc., 04-11-2005 19:05:56
Not hard to fix, just a seal out on the pump shaft. Remove the pump, remove the drive gear, pull the old seal, get a new seal from your local Case-IH dealer, and you're back in business.
