H Carb Leak (update)
PurdueAg
04-11-2005 19:15:50
I figured out what caused the carburator to start leaking like a seive without warning. I had put gasoline in the tractor a week ago and started and ran it for the first time. It turns out there was a tiny hole in the float and it took about a week to fill with gas, and when it did, I ended up with four gallons on the floor (among other things, I am going to remember to turn off the gas after each use!). Thanks to Don LC, Rusty Farmall, and Peabody for the helpful advice on an earlier post.
Now, how do I patch the hole in the float (brass)?!
Tony
old
04-11-2005 20:42:23
 Re: H Carb Leak (update) in reply to PurdueAg, 04-11-2005 19:15:50
If I where you I'd just buy a new float $20 cheap and then you know its good and you also will not have the worry of it blowing up in your face if you screw up
PurdueAg
04-12-2005 07:25:53
 Re: H Carb Leak (update) in reply to old, 04-11-2005 20:42:23
Old,
Where can I buy one? Do the Case dealerships sell them?
Thanks,
Tony
RustyFarmall
04-12-2005 07:52:33
 Re: H Carb Leak (update) in reply to PurdueAg, 04-12-2005 07:25:53
Purdue, I purchased a new float for my M from my local Case-IH dealer about two years ago. Didn't even have to order it, it was on the shelf. I would imagine that an H would be just as available.
PurdueAg
04-12-2005 07:56:31
 Re: H Carb Leak (update) in reply to RustyFarmall, 04-12-2005 07:52:33
Thanks, I'll sneak over to the Case dealer after work! Buying a new float will be cheaper than buying a new soldering gun, flux, and solder!
Tony
old
04-12-2005 09:17:47
 Re: H Carb Leak (update) in reply to PurdueAg, 04-12-2005 07:56:31
Also if they don't have one this site or value bilt has them
PurdueAg
04-12-2005 09:19:48
 Re: H Carb Leak (update) in reply to old, 04-12-2005 09:17:47
I tried to find one on this site, but the rebuild kits didn't appear to have floats with them. I'll check again.
old
04-12-2005 09:44:47
 Re: H Carb Leak (update) in reply to PurdueAg, 04-12-2005 09:19:48
Floats aren't part of a kit it has to be brought by its self.
P Backus
04-11-2005 19:21:50
I have fixed brass floats by drilling the hole out to 1/16 so you can get all the gas out, then clean and flux the brass and solder it with a small iron.
Paul
PurdueAg
04-11-2005 19:26:44
 Re: H Carb Leak (update) in reply to P Backus, 04-11-2005 19:21:50
Thanks Paul. I'll try that (already did the pin prick to widen the hole to get the gas out -- will try soldering tomorrow!).
Peabody
04-11-2005 20:10:30
 Re: H Carb Leak (update) in reply to PurdueAg, 04-11-2005 19:26:44
PerdueAg, Hope that works for you. But one leak in the float may be an indication that the entire float wall has corroded to the point that you will experience future leaks rather soon. It did that to me a couple of years ago. I used JB Weld instead of solder. Make sure you use as little as you can, cause the stuff is heavy. I sealed one hole, but several months later another developed; I sealed it, and next thing I know the float is just too heavy with all the patching to do its job. That's when I had to beg on this sight for a NOS replacement float for a Carter carb. You know the rest of the story. The guys on this sight came to the rescue. My NOS float has my 52 SC running good as gold (except I got to let that durned nest of wrens twixt the radiator and fan fledge afore I can crank her up again!)
PurdueAg
04-12-2005 07:23:59
 Re: H Carb Leak (update) in reply to Peabody, 04-11-2005 20:10:30
I wondered about JB weld. I use that stuff all the time, but wasn't sure if it would dissolve in gas after it set up. Thanks for the tip.
Tony
captaink
04-12-2005 11:30:39
 Re: H Carb Leak (update) in reply to PurdueAg, 04-12-2005 07:23:59
I have heard (no experience personally) that JB will hold up for sealing gasoline leaks, but will not work on Diesel fuel becasue of the oily naiture. Seems to make sense, so I thought I'd pass it along...
RustyFarmall
04-12-2005 12:47:11
 Re: H Carb Leak (update) in reply to captaink, 04-12-2005 11:30:39
JB weld will hold up to gasoline, I have used it to patch gas tanks on cars and trucks when they got punctured from something on the road, worked very well. I also used JB weld to secure the small riser pipe I installed in the inlet of the sediment bowl on my M, that part is completely immersed in gasoline all the time. Three years later it is holding up just fine.
PurdueAg
04-12-2005 11:33:48
 Good to know. Thank you (nm) in reply to captaink, 04-12-2005 11:30:39
nm
