Will a C-135 head work on a C-123? HELP
MM_TX
04-11-2005 22:27:29
Will a 9 bolt C-135 head #366299 with the big valves and smaller chamber have enough clearence on a SC C-123 with 3.125 step head pistons? Will the C-123 rocker assembly & push rods work? Will the C123 exaugst work? Will the increased compression make it more tempermental? I'm not making a puller. Thanks for any help MM
Shaggy
04-12-2005 06:14:28
 Re: Will a C-135 head work on a C-123? HELP in reply to MM_TX, 04-11-2005 22:27:29
I have a 140 head on my B with step head pistons and it works fine. I test fitted the head before I put it on. Put it on with no gasket and slowly turn the engine over (with a hand crank) and if it clears with no gasket you should be good. The 123 will fit and try the rockers before making everything permenant.
