Order Farmall Cub Parts Online
Woods 348 belly mount finish mower for Farmall Cub
Tim Kelly
04-11-2005 23:08:44
I purchased a 1963 Farmall Cub and an unattached Woods 348 finish mower (no other hardware included). I don't know if the mower will fit on the Cub. How do I find out? I've just purchased a used cub woods mower draw bar and bracket assembly including the two idler pulleys to (hopefully) run the belt around the back of the tractor. Also, do I need a special size pulley on the pto shaft for this mower?
Bigdog
04-12-2005 07:49:56
 Re: Woods 348 belly mount finish mower for Farmall in reply to Tim Kelly, 04-11-2005 23:08:44
A Woods dealer can tell you if they make an attachment kit for your mower to mount it on a cub. Most rotary mowers used with a cub are driven with a 7 or 8 inch drive pulley. The typical Woods mowers used with a cub are either the 42C or the L59. Don't know if a 348 will fit or not. You might check the link for a look at manuals and mounting for these two mowers.
Bigdog
04-12-2005 07:55:50
 Re: Woods 348 belly mount finish mower for Farmall in reply to Bigdog, 04-12-2005 07:49:56
Copy and paste this link:
http://www.cleancomputes.com/Cub/OEM%20Implement%20and%20Attachment%20Manuals/Woods%20Mower%20Manuals/index.html
