octane for farmall H? 87, 89, 92
arod
04-12-2005 09:19:43
Curious if a higher octane will make a noticeable difference in these old engines?
Tractor has sat for 15 years. Just tore it down, honed cylinders(there were in good shape). Put it all back together with a rebuilt carb, conversion to 12V complete with new plugs, wires, coil, alternator, etc...
Did not touch the clutch or transmission on the rebuild. Hope to hell they work when I engage them.
The belly pump is missing the dipstick, how can a fella ensure proper fluid level in there?
RustyFarmall
04-12-2005 12:35:35
 Re: octane for farmall H? 87, 89, 92 in reply to arod, 04-12-2005 09:19:43
87 octane will be just fine, however, 10% ethanol is 89 octane, and usually 2 cents a gallon cheaper. Your H will run just fine on that also.
sammy the RED
04-12-2005 11:49:25
  octane for farmall H? 70-72 octane in reply to arod, 04-12-2005 09:19:43
Your "H" was designed to run on 70 - 72 octane.
MagMan
04-12-2005 09:43:09
Hi Arod I beleve the tractors were made to run on low octain . The higher the octain the cooler they will run.I beleve with the high compression kit it would run a little better with higher octain but I think for what you did you would be waisting your money running anything over 87. I have not ever ran a dipstick I just fill her up untill she works good and if she gets slow I ad a quart. I dont think you would hurt it to over fill her I will measure a dip stick and let you know so you can make one out of wire to check it with. JON
dhermesc
04-12-2005 10:05:41
 Re: octane for farmall H? 87, 89, 92 in reply to MagMan, 04-12-2005 09:43:09
I agree with MAGMAN, these are low compression engines, even with the "high compression" kits they have lower compression then "modern" (1960s+) engines. 87 octain will be just fine for most any application.
arod
04-12-2005 09:59:18
that would be great, thanks
MagMan
04-12-2005 11:51:50
 Re: octane for farmall H? 87, 89, 92 in reply to arod, 04-12-2005 09:59:18
the Rod is 1 Foot long with a washer at the top so it cant fall in and the full mark is between two lines the first line from the bottom being 2" and the upper line at 2 and 1/4" JON
RustyFarmall
04-12-2005 12:38:25
 Re: octane for farmall H? 87, 89, 92 in reply to MagMan, 04-12-2005 11:51:50
Even if you overfill the pump, the worst that will happen is the oil will come back out the fill tube, and make a mess, nothing else will be hurt.
