Serial # Stamp On Block Of H
MagMan
04-12-2005 09:37:38
Hi Guys I just noticed something I was just looking at the new H its a 51 366484. I beleve ok the serial # is in a block at the rear of the motor above the oil filter. OK Now I was just lookin at my other H and the serial block is at the front of the motor with the serial stamp in that one being 322xxx 1949 I guess is that something they changed over the years or was that not specific. Or maybe one plant cast it in a different place than the other? JON
williamf
04-12-2005 14:52:07
 Re: Serial # Stamp On Block Of H in reply to MagMan, 04-12-2005 09:37:38
Mr. Haney, who's a '46, has the Ser.#FBH 221654 (which matches the number on the plate on the bell housing, thank goodness) stamped on a flat spot on the right front of the block, slightly above and just ahead of the magneto. I haven't found it in any other places yet, but I only recently noticed that one.
Wm
BTW, I notice he has no suffix. I know there were suffixes that told fuel type or brand of clutch or such. Wonder why this one, a distillate or kerosene burner by the extra gas tank and manifold with the jacket and lever, wouldn't have one?
RustyFarmall
04-13-2005 08:48:06
 Re: Serial # Stamp On Block Of H in reply to williamf, 04-12-2005 14:52:07
Williamf, since the distillate burning engine was the "standard" engine, there would not be a suffix. The suffix was used to denote options, or differances from the normal H.
RustyFarmall
04-12-2005 12:29:40
Maybe your engine is installed backwards? Don't know, it's a new one on me. I am pretty sure that my 50 H is just like all the rest of the Hs I've ever seen.
