Front Blade on a Super A
DelMN
04-12-2005 11:38:27
Has anyone ever seen a front blade on a Super A? I haven't. If so, does anyone have one? Is it possible to make a Cub blade fit?
Next: Can one take a Woods belly mower from a Farmall B and put it on the Super A?
Thanks in advance guys--you're the greatest!!
Jim Becker
04-13-2005 18:10:10
 Re: Front Blade on a Super A in reply to DelMN, 04-12-2005 11:38:27
Forget the Cub blade. You would need to stretch it by about 1/3 in every direction.
fredmich
04-12-2005 19:01:44
Yes IH sold a blade for the superA that could be used as a mid mount grader blade and as a front mounted push blade. It works great on my Super A. They are not that hard to find used and I think Stieners sell parts for the new ones. As for the woods mower question the setup is quite different between the B or BN and the A's. The B and BN use the large 18" pulley on the main pto shaft and the A uses a pulley mounted where the belt pulley is. The reason is the 18" pulley would interfere with the left rr wheel on the A because it doesn't have a extended l.h. rear axle. The mower deck I think is the same but the blades are different because of the rotation. The sub frames are quite different because they bolt to the inside of the drop axles. Woods has a neat sales brochure showing their mowers on vintage tractors. I've mowed with one on my BN for 20 years and its been great!...Fred
gene b
04-12-2005 15:19:38
The drive pulleys are on a different set-up. It would take some new welded brackets to make it work. You can get them from WOODS but it wont be cheap.
