1568 Questions????
cgilreath02
04-12-2005 15:36:14
I have a few questions about the 1568"s. Did all 1568"s come with cabs and does anyone know if any 1568"s slipped out of the plant with a 1468 serial # plate?? I have located a 1568 , but it has a 1468 tag. Can anyone explain this maybe?? Thanks in advance, Chad
K.B.-826
04-12-2005 16:27:02
 Re: 1568 Questions???? in reply to cgilreath02, 04-12-2005 15:36:14
The serial number tag was loacted on the speed transmission housing, which means that it will have the 4-speed, making it a 1468. Someone's trying to pull one over on you.
scot_c
04-12-2005 17:18:21
 Re: 1568 Questions???? in reply to K.B.-826, 04-12-2005 16:27:02
that's where it is on both models, if it's got a 3 speed +hi/lo it's a 15 if it's got a 4-speed its a 14. most 15's I've seen have cabs probably because they are so heavy, I don't pay much attention to 14's
cgilreath02
04-12-2005 18:34:35
 Re: 1568 Questions???? in reply to scot_c, 04-12-2005 17:18:21
The tranny is a 3speed with T/A, so its a 6 speed,which makes it a 1568 and the side of the tractor says 1568, but the serial # on the clutch housing says 1468. Tractor has both pto"s and dual Hyd. outlets. But I can"t figure out why it would have a the wrong tag, b/c the tranny and rearend on a 14 will not interchange with a 1568.Thanks again , Chad
scot_c
04-13-2005 19:36:29
 Re: 1568 Questions???? in reply to cgilreath02, 04-12-2005 18:34:35
the t/a housing could have been changed I think that casting is the same on all the large frame tractors. The dual pto will bolt right into a 15 it could be done but the factory wouldn't do it.
chadd
04-13-2005 09:42:46
This might be wrong, but I thought that 1566's couldn't have the dual pto. I thought that they all got just the 1000 pto because IH felt that it had too much power to run through a 540 rpm pto drive. Regardless, something seems a little weird here. . .
w gatewood
04-12-2005 19:36:32
the ta housing was changed
