Second Time Post For Serial # Location H Block
MAGMAN
04-13-2005 05:42:59
In case some of you missed this yesterday I posted with an H block that had the serial # stamped in a block on the rear above the oil filter. Every other H I have seen has it in the front above the Mag. What makes this one so special . Year? Or What. Thanks again MagMan
RustyFarmall
04-13-2005 11:35:55
 Re: Second Time Post For Serial # Location H Block in reply to MAGMAN, 04-13-2005 05:42:59
OK, after looking at the pic, I just had to go out and take a look at mine. The 1950 has the serial number in the same location as your 51. The next newest H I have is a 46, and it has the number up to the front.
MagMan
04-13-2005 11:59:44
 Re: Second Time Post For Serial # Location H Block in reply to RustyFarmall, 04-13-2005 11:35:55
What do you think of the casting codes not matching one 50 and one 51 did that happen alot too. JON
RustyFarmall
04-13-2005 12:18:56
 Re: Second Time Post For Serial # Location H Block in reply to MagMan, 04-13-2005 11:59:44
Casting codes won't always exactly match, usually the letter for the year will be the same throughout the tractor but if the tractor was built very early in the year it could very easily have components with last years date on them. I would say that T and W would not be too unusual.
MagMan
04-13-2005 09:29:19
 Serial # Location H Block Picture in reply to MAGMAN, 04-13-2005 05:42:59
third party image
Ok lets see if this works other wise its in the help identify I beleve under 51 H magman It looks like the Motor it casting T and the rest W but maybe I am wrong the serial # on the bellhousing does match the motor.
Link
kfox
04-13-2005 10:56:06
 Re: Serial # Location H Block Picture in reply to MagMan, 04-13-2005 09:29:19
I have a 52 H engine block-Serial #383405, casting code 4-9-X (1952), part # 6695-DF, and the serial # is stamped above and just a little in front of the oil filter. Looks the same as yours. ken
DWV
04-13-2005 09:56:50
FBHM is standard prefix for H engine and apears
to be original. To help little more what is # and suffix letters below # 4 spark plug?
MagMan
04-13-2005 08:30:04
No Its just like the front serial same block just in the rear like an M. I will get a pic and post itr today . And check the castings for a difference. JON
DWV
04-13-2005 08:41:17
 Re: Second Time Post For Serial # Location H Block in reply to MagMan, 04-13-2005 08:30:04
Another thought,you wouldnt buy any chance be looking at the 6 didgit cast number on a newer
block than came in tractor instead of serial #?
DWV
04-13-2005 08:29:33
Magman need more info,what is casting # on block,
date code and is dip stick hole drilled with a plug or a dip stick in it.On a H most all block serial # match tractor serial #.
MagMan
04-13-2005 08:39:28
 Re: Second Time Post For Serial # Location H Block in reply to DWV, 04-13-2005 08:29:33
I will check casting but yes the # does match bell housing # also. JON
DWV
04-13-2005 08:53:56
 Re: Second Time Post For Serial # Location H Block in reply to MagMan, 04-13-2005 08:39:28
Magman is the pad with stamped # below and little
to rear of # 3 spark plug or above and just ahead
of oil filter.Thats where newer blocks had serial
MagMan
04-13-2005 09:18:14
 Re: Second Time Post For Serial # Location H Block in reply to DWV, 04-13-2005 08:53:56
Yes Exactly I am going to down load a pic in a min but I am not sure if I can get it here never had much luck. So its just that its a newer block being a 51 that they stamped in the rear instead of front. Also the ser is FBHM 366xxx whats the M for? JON
williamf
04-13-2005 07:29:29
Does the spot where it's stamped look like the spot over the mag where the others are stamped? That is, like it was flattened and milled smooth first as opposed to just being stamped into the rough cast surface?
Wm
RustyFarmall
04-13-2005 06:51:28
Magman, you do have me curious, is there anything else different on this engine? How about the casting codes? A friend of mine was working on an M and we discovered that the casting code on the engine block did not match up with any codes that would have been correct for an M. In fact, the codes put the date of casting somewhere around 1959 if I remember correctly, and it was an M block. Not super, not 400, not 450.
C'Mon
04-13-2005 06:34:30
Hey man, don't take a lack of useful responses personally. It's not that you've been shunned by the community, or that your question is too stupid... It's because nobody knows why, that's all. Only somebody with intimate knowledge of the history of manufacturing processes at IH in the 1940s would know, or know where to find such information. There aren't too many of them around anymore.
Slappy
04-13-2005 06:07:35
Jon, I think mine is stamped above the oil filter too - but I'll check for sure.
Making progress on the rebuild?
