1206 Top plate Fix
ol_timer
04-13-2005 07:33:52
The shaft through the speed transmission cover is pinned & keyed to cam. Question is what type of roll pin is supposed to be put in to replace?? Mine is broke cant tell what it was original. Something hard so it wont happen again maybe?? THANKS
the tractor vet
04-14-2005 07:48:25
 Re: 1206 Top plate Fix in reply to ol_timer, 04-13-2005 07:33:52
They are suppose to be a taperd groved pin but you can drill them out to spiraled rolled pin or you can take make a pin but it must fit tight. i have used 5/16th bolts and lock nuts but you must grind off about 2/3rds of the head for clearance .
K.B.-826
04-13-2005 21:59:36
Double roll pin, wrap a wire through it.
