400 oil pressure
David A. Hodson
04-13-2005 16:15:02
the oil pressure drops to almost nothing after tractor warms up, I'm thinking possiblymains and rods, what do you guys think, note carries about 60 PSI when first started. Thanks in advance David
El Toro
04-14-2005 05:12:33
 Re: 400 oil pressure in reply to David A. Hodson, 04-13-2005 16:15:02
I don't think you should run that tractor with low oil pressure. I would drop the oil pan and
look at those main bearings. Use some plasti-gage
to determine wear and what clearances you have now. Cam bearings that are worn willcause low oil pressure too. Engine probably needs to be rebuilt. You do not want to ruin the crankshaft
or worse like a thrown rod. Hal
JOSSETTE
04-13-2005 18:56:49
new guage is $35 ... if that isnt the problem you have for the rebuild.
try the breather tube filter.. if that is plugged the pressure will go down too.
David A. Hodson
04-13-2005 20:09:25
 Re: 400 oil pressure in reply to JOSSETTE, 04-13-2005 18:56:49
thanks I'll check it out this weekend, 10:06 my time gotta get some sleep for work tomorrow David
Allan in NE
04-13-2005 16:47:03
Dave,
It's worse than ya think. Bearings are the very last thing to wear out in an engine. Just imagine what the rest of 'er is like.
I think ya oughta think about a major on this ol' sweetie.
Allan
David A. Hodson
04-13-2005 17:44:22
 Re: 400 oil pressure in reply to Allan in NE, 04-13-2005 16:47:03
Allen if I do I know tjat everybody will give me heck 'cause I'll build the engine as a 450. I'm hoping she make it through the summer and hopefully I'll be able to start on her this winter. when I do start on her I want go through front to back, top to bottom. Thanks David
David A. Hodson
04-13-2005 16:27:33
CaseIH low ash SAE 30, and she done it with the old gauge and new one does same thing that why I'm thinking mains. Thanks David
El Toro
04-13-2005 16:22:55
Could be it needs mains and cam bearings. What wt oil are you using? I like 30wt if you're working that tractor. Hal
PAULIH300
04-13-2005 16:21:24
What is the oil weight? Maybe should use something a little heavier? Could be a bad gauge?
