wiring for M
Ed Selander
04-13-2005 16:32:38
I have a 1942 M serial # 56106.Somtime before I bought it,it was changed over to a 12 volt with a dist.and coil. a Ford regulator and alternator. It was running when I got it,but I stripped it all down to restore it.Problem is,the wiring was such a cobbled up,tapped up mess, that I tore it all out.Now I don't know what wires (new wires) goes where. I should have left the rats nest wiring on and replaced one wire at a time. at least it ran. HELP !! Ed
bermuda ken
04-14-2005 05:56:14
 Re: wiring for M in reply to Ed Selander, 04-13-2005 16:32:38
It sounds like you desperately need a new wiring harness too. Taping up an old cut-up and fragile harness will only lead to a fire. Try this to see what you need:
www.cngco.com/oem.electric.html
David A. Hodson
04-13-2005 17:56:10
Ed you didn't say what alt. your using. David
Larry in CO
04-13-2005 17:52:17
Punch the link below for Bob Melville's excellent wiring diagrams. I couldn't have done my H without them. HTH Larry
