Order Farmall Cub Parts Online
Cub Loboy help needed
Bixley
04-13-2005 17:11:47
I need to know what the timing should be set at on my Cub Loboy. I just put an electronic ignition in my tractor and I want to make sure the timing is set corectly. Also, what is the correct carb number for this tractor? I think someone may have switched carbs and put the wrong one on here. Thanks,
Bixley
El Toro
04-14-2005 09:37:28
 Re: Cub Loboy help needed in reply to Bixley, 04-13-2005 17:11:47
The timing is TDC and the timing notch is on the flywheel. Someone on the Cub forum can probably answer your carburetor question. Hal
