electrial problem on 986
Alvin NE WI
04-13-2005 17:54:03
on our 986 we can not get the radio and air and heat to work because of no current up there. the light up there work and also thr flashers. We put a new switch in and it did not help. When we put current direct from batteries to air and radio it works but not with the wire from the start switch. Where would the cuprit me at? thanks
Alvin
David A. Hodson
04-13-2005 17:58:53
 Re: electrial problem on 986 in reply to Alvin NE WI, 04-13-2005 17:54:03
Alvin we had same trouble on our 886, replaced the solenoid down in the console under the dash and everything works perfectly Good Luck David
