Distibutor location on H
Rich Iowa
04-13-2005 19:20:36
I was looking at my H today and noticed that the distibutor and coil are positioned vertically, not horizatally as I've seen in my repair and operator's manual. The coil is located behind the dist. looking from the front of the tractor. I've never noticed this until today. When did IH change the position of these and does it make any differance? TIA Rich
Larry in CO
04-13-2005 19:42:00
 Re: Distibutor location on H in reply to Rich Iowa, 04-13-2005 19:20:36
You've got one of the Delco aftermarket distributers. These were commonly used to replace a mag that went bad. I've got one on my H and it works well. By the way, you can get the points, condenser, rotor, cap and stuff at your local NAPA. I can't remember the part numbers offhand. HTH Larry
