1964 Farmall 706 value
Scott Farmall
04-14-2005 11:27:09
The tractor has a wide front end with a loader, there is a tooth missing on the reverse gear and the park brake is being repaired now, The rear tires are about 40%, and it has a gas engine that was rebuilt around 1986 and it seems to run good and doesn't smoke.His bottom dollar is 3000.00, is it worth it?
RustyFarmall
04-14-2005 12:02:26
 Re: 1964 Farmall 706 value in reply to Scott Farmall, 04-14-2005 11:27:09
If the present owner makes the repairs first then $3,000 isn't too bad. I wouldn't pay that for the tractor in it's present condition
Scott Farmall
04-14-2005 12:07:40
 Re: 1964 Farmall 706 value in reply to RustyFarmall, 04-14-2005 12:02:26
He's only fixing the park brake, the reverse gear with the missing tooth will not be fix.
the tractor vet
04-14-2005 13:04:34
 Re: 1964 Farmall 706 value in reply to Scott Farmall, 04-14-2005 12:07:40
Fixen the park paw ain't nothing but fixen the gear now that take some handy work and a lot off bull work and the job's not done till that is fixed . and if you end up doing the work well that is one thing but if ya have it done then ya better dig deep cause it is going to cost some schekels . This happens when one dropes the park while still moving . But for 3 large with a loader is not to bad and leaves some room to fix and still be ok .
RustyFarmall
04-14-2005 13:02:02
Walk away from it. This tractor could turn into a money pit.
the tractor vet
04-14-2005 13:12:09
 Re: 1964 Farmall 706 value in reply to RustyFarmall, 04-14-2005 13:02:02
Hey rusty it's only money and ya can't take it with ya. and once fixed he will have one good tractor . When ya sell a 706 to a die hard Deere lover because he was a littel down on his luck and now that he is doing well what does he owen now but all red ones that i have fixed for him and he is the one that i have down at this time for a piston and do you think that i can get him to get rid of it heck no he is in love with that 706 . It does all the planting , mowen , sprayen some of the baling all the wagon pullen silage packen all the snow plowen and some of the turd herder operation and what ever else comes along .
Scott Farmall
04-14-2005 13:35:08
 Re: 1964 Farmall 706 value in reply to the tractor vet, 04-14-2005 13:12:09
Darn, I was hopin somebody would say "it's no big deal, run it with a broke tooth if the click-click in reverse doesn't bother ya". If it is to be fixed if would be by me, and all those gears are over my head. one other thing is that it's next door to me and there would be no haul bill.
caseyc
04-14-2005 19:24:02
 Re: 1964 Farmall 706 value in reply to Scott Farmall, 04-14-2005 13:35:08
i have a 706G that i bought two years ago. i paid $5200. it has 11000hrs on it. has a IH2000 loader and a grapple and cab came with it, not mounted though. i get home only to find out the t/a is shot, tooth broke off in reverse amongst other things. it only clicks in 3 or 4 reverse, never in 1 or 2. i never use 3 or 4 so no big deal. before i bought it i stomped hard on the brakes with the t/a pulled and it killed so i thought i was good, wrong! then that winter the head gasket blew. i guess i'm just a sucker for 706's. i love them to death and am trying to find one with a 310 german now. despite all my bad luck i still love it and wouldn't get rid of it for nothing. i say buy it. i don't think you'll be sorry no matter what you have to do to it.
casey in SD
the tractor vet
04-14-2005 14:08:21
Well one thing for sure it won't fix it's self and in time it will get worse and yea i know someone is going to say mine has been that way for years and it is fine but what happens if the tractor is parked on a hill and that tooth that it is engauged is almost broke thru and it breaks and the tractor runs off and runs over some littel kid or across the road and hit a car or runs over you . I had one jump out of park on me and that will wake you up now if i get one that has not been changed over to the spring loaded one it gets it and if i have a clicker then it gets fixed . There are enough people that get hurt on tractors every year because of this or that so why add to the list.
