Behlen hydraulic pump
Chris Willy
04-14-2005 18:46:39
Hey guys, I was wondering if anyone knows where to find seals for a Behlen hydraulic pump for an M that is mounted in front of the distributor. If anyone could get me phone numbers or links or anything i"d appreciate it, thanks alot.
Chris Willy
Bob
04-14-2005 19:29:43
 Re: Behlen hydraulic pump in reply to Chris Willy, 04-14-2005 18:46:39
Behlen is still around, altough not in the tractor accessories business. I emailed them a couple of years ago, and they replied with a source from outside their company for parts for the power steering units. I no longer have the reply (although the information should be in the archives here, or on the Deere board, since I posted it at the time, if you care to search), but here's an email address for Behlen. Hopefully, they still have that information and will reply.
Behlen email:
behlen@behlenmfg.com
Most likely, the shaft seals are common off-the-shelf parts, most likely made by National or Chicago Rawhide. Look for numbers on the seals, and check with a local industrial bearing shop or hydraulics repair shop.
Joe A.
04-14-2005 20:22:38
 Re: Behlen hydraulic pump in reply to Bob, 04-14-2005 19:29:43
I have gotten seals for mine (on a Super M) by going to local IH and claiming to have a Farmall 300 with power steering (uses the same steering motor, not sure if it has a pump, though. Haven't needed anything for my pump yet). That seems to not cause confusion with aftermarket cross-referencing on their part!
Joe A., Corydon, IN
