1943 farmall H temp
dan67
04-14-2005 20:04:44
Did some heavy pulling the other day, ripping an old pasture, Temp ran approx 160 ran that way all afternoon. At idle dropped to 140 almost immdeatly. It's a hard worker. Is that a acceptable temp. Thanks for any advise.
dan67
04-15-2005 19:26:32
 Re: 1943 farmall H temp in reply to dan67, 04-14-2005 20:04:44
Thanks for the great infor. I'll look to see if the t-stat in not up to par
El Toro
04-15-2005 05:28:11
I agree with Old on the higher operating temp.
Those old tractors may still have the 160 degree
thermostat when they used alcohol antifreeze. Such as Zerone. Haven't heard that word for years.
That's what we used when I was a kid. Too high of a operating temp would boil away the alcohol.
The 180 to 195 degree range keeps out any sludge
too. Hal
old
04-14-2005 20:46:41
Sounds a little low, does it have a thermostate??Should run more like 180-195. Engines run better if up around the 180-200 range.
