Farmall H M weights
R. Mizell
04-15-2005 08:45:31
What is the total tractor weight for the Farmall Model H and also the total weight of the Farmall model M?
Thanks,
R. Mizell
Brainerd Dave
04-15-2005 10:19:25
 Re: Farmall H M weights in reply to R. Mizell, 04-15-2005 08:45:31
I dug around and found it.
The M shipped at 4858 lbs.
Brainerd Dave
04-15-2005 10:08:11
Shipping weight from the factory for an H was 3140 lbs including lubricants but no fuel or water.
Not sure on the M.
RustyFarmall
04-15-2005 10:26:59
 Re: Farmall H M weights in reply to Brainerd Dave, 04-15-2005 10:08:11
I might add that those weights are for the bare tractor. No belly pump, no PTO, no belt pulley, and no swinging drawbar. Possibly not even a starter or electrical system. Have I missed anything?
Harley
04-15-2005 17:30:02
 Re: Farmall H M weights in reply to RustyFarmall, 04-15-2005 10:26:59
Just as a rule of thumb, back when I used to haul tractors back in the old days before fuel cost explosion, I figured around 4,000 lbs for an H and 5,000 for an M. Every tractor will be a little different, so these usually caught most things if they didn't have weights or loaded tires. Harley
