FARMALL 504 VOLTAGE REGULATOR
HAY GUY
04-15-2005 13:53:40
Did the 504 come with a voltage regulator? Mine currently doesn"t have one.
El Toro
04-16-2005 10:07:59
 Re: FARMALL 504 VOLTAGE REGULATOR in reply to HAY GUY, 04-15-2005 13:53:40
Put a volt meter across the battery terminals with engine running from 1/2 to 3/4 throttle and
see what your voltage reading is. A 12 volt system should read between 13.5 to 14.5 volts and the 6 volt system around 7.5 to 7.75. If your tractor has been starting ok with the starter, the battery is probably charging ok. Hal
Bob M
04-15-2005 19:37:37
The 504 would have come from the factory with a voltage regulator. Unless it"s been converted to an internally-regulated alternator the charging system won"t work without one!
