H Hydraulic and rear end fluids
railroadgoat
04-15-2005 17:27:00
Hydraulic, how much and what kind ?? Transmission, ??? Rear end, what kind and how much ?? 1947 model H. Don"t have any books yet. Thanks
Don L C
04-16-2005 09:33:09
 Re: H Hydraulic and rear end fluids in reply to railroadgoat, 04-15-2005 17:27:00
This information is out of my H IHC Service manual:Crankcase oil pan 6 qts. --- Trans. and differential case:6 gal. 80w; 90wt; 140w...the 140 is usually used in extreamly hot climate...heavy loads.
GNB
04-15-2005 18:56:55
I use Hytran in belly pump(30WT non detergent can be used and was what was originally used in the belly pumps). Think it holds about 6 quarts, but dont hold me to it. The transmission I run straight 90 WT gear oil(can run 80-90wt or 140wt) If you have bad seals probally want to go with heavier gear oil. I dont have my manual but 24 Quarts rings a bell for the transmission. Hope this helped.
GNB
