240 loader hydraulics question
Dave D
04-16-2005 05:14:54
third party image
My local equipment dealer just did some "depot-level maintenance" on my 240 loader and it is steering and running great now. (Note: woodruff key was sheared.) They replaced some hoses, drained and replaced the hydraulic filter, and they installed a little breather vent on top of the loader hydraulic fill hole which they said the system needed. There had been a pipe plug, maybe about 1.5" in diameter there before for the last 45 years and it was located on top of a tubular loader frame structure (hoping for a hosted image here in this message). This loader is a "Superior" model with a Husco controller.
I only got it back last night but my issue is, whenever I am lowering the arm, hyd oil flows out of the 'breather' vent, maybe up to a cup at a time. I noticed it dripping at the shop and the mechanic said they hadn't known how much fluid it would take and it really wasn't a problem. He told me to always make sure I lowered the bucket with the engine running to keep the system pressure equalized. But using the loader for an hour last night, the fluid keeps flowing strongly (but not spraying) out of the breather every time I lower the arm.
Should I be concerned? Did the equipment place "fix what weren't broke" and screw me up here by installing this little breather apparatus? They were nice Massey Ferguson guys and I don't want to beat on them unnecessarily. But I don't want my 1961-era hydraulics to bleed to death out in the woods either, because somebody thought my unit needed a breather suitable for a late-model system. The loader had always worked great before but hoses were rusted on and down to the nylon (!) cords.
Thanks, guys,
Dave D in New Hampshire
PS, the image of the breather on the tractor is failing to come up for some reason.
PAULIH300
04-16-2005 15:01:24
 Re: 240 loader hydraulics question in reply to Dave D, 04-16-2005 05:14:54
I know what they mean by lowering the loader with the engine off....mine overflowed when I lowered it shut down.It was rather foamy anyway (bad pump seal I learn)but it never did that when running.Of course its single acting rams,so maybe that had something to do with it.
As for the vent,there needs to be a system vent somewhere....remote or a hole in a filler cap.The air pressure needs to be equalized when fluid is coming out and going back in.
JJK
04-16-2005 06:48:24
First check to see how much oil is in the resevoir and if its between half and 3/4 full I would put the plug back in and not use the breather that they had installed. If they filled it to the top then the oil will push out until it can't anymore. Hopefully sombody with more experience on these systems than me can elaborate more on this cause I've only monkeyed with a handfull of these loaders.
