IH B250 Diesel
Jim Squires
04-16-2005 10:34:37
Hi guys.
I recently bought a B250 Diesel with a good working engine and hydraulics and would like to know if the dual clutch and dual range transmission from a B275 will fit engine and rear end I have? I have read the that the B250 and B275 are basically the same tractor with the obvious clutch and tranny differences. The main reason for asking is I would like to put a blower on the back but the reverse is to fast.
Please post/email me any info anybody might have if this is possible or should I be looking for a another tractor.
Thanks for any input/help.
Jim
Michael Soldan
04-16-2005 13:11:28
 Re: IH B250 Diesel in reply to Jim Squires, 04-16-2005 10:34:37
Jim, I think it would be easier to mount a blower on the front than have to change the whole rear end. I am under the impression that B250/B275 are basically the same tractor and I think you can swap rear ends, you could also mount a shaft under up to the front and run a small blower with a single ram to lift it. They are great little tractors. Good luck from Mike in Exeter Ontario
