M power steering problems still
Chris Willy
04-17-2005 21:09:41
Hey guys, I am workin on that M still and so far I"ve put a Behlen power steering unit and a Behlen distributor pump on the tractor, I got the pump from my grandpa"s farm and noticed it was painted green, didn"t really think to much of it, but anyways, after gettin it all on the tractor and hooked up it worked great for a day or so then developed a decent sized leak from the front of the pump unit. So I found new seals for the pump and put those in, thought I had the problem fixed and I put it all back together and it still leaks. I have two thoughts of why this is still leaking. My first is that the shafts of the pump are slightly wore that the seals aren"t quite tight enough, or I noticed that on the pump the pressure side of the pump is half inch, while the return side of the pump is 3/8, is this right, or should it be the other way around and my tractor is turning the pump the wrong way?? This pump may have been for a JD, would that make a difference? Sorry bout the long post but thought I needed to really explain so you guys might be able to help me out. Thanks alot.
Chris Willy
Farmalldan
04-18-2005 06:35:32
 Re: M power steering problems still in reply to Chris Willy, 04-17-2005 21:09:41
Chris,
If you have the pump which fits between the magneto/distributor flange and the magneto/distributor, you have a JD pump. I believe it turns counterclockwise facing the input shaft (backwards for your tractor) and your piping connections would support this. As Gene said, the small port is the high pressure port. Running a hydraulic pump backwards subjects the case, including the shaft seal, to the high pressure. In addition to not being able to keep a seal in it, you also risk rupturing the case. I recommend obtaining the correct live hydraulic pump for your Farmall or add a belt driven PS pump. The IHC live pump will have too much output for power steering only unless you can use the surplus for your lift. An older (to get a v-belt sheave instead of poly groove)automotive power steering pump will likely work fine.
gene b
04-18-2005 01:00:34
Return is larger so as not to impair flow.
