Farmall B hood
FC
04-18-2005 05:26:32
This weekend I 'rescued' a hood from a Farmall B. What other models will this fit? It looks like the same hood that is on my C, and I would assume it would also fit a Super C, and possibly Super A? It has the J hook type fasteners. I know there were some early hoods with different fasteners, but I cannot remember whether they were on the early A or B models or both.
Mike@NY
04-18-2005 09:16:59
 Re: Farmall B hood in reply to FC, 04-18-2005 05:26:32
The hood you have should fit an A, B, BN, and SA (maybe others too). I do know that the hoods from my A and SA are shorter than the hood on my C (ie not as long), so I do not believe it will fit the C and SC. It does have the similair fasteners and all. The early ones on an A and B have the fasteners mentioned earlier. Hope that helps. Good Luck.
A or B
04-18-2005 06:05:17
The "core," that is, the tranny, engine, and superstructure of both the A and B are essentially identical. That hood should fit just fine.
Originally the hoods fastened with Dzus fasteners, but AFAIK, that was only in 1939 and 1940. Not sure why they quit doing it. Maybe the war?
