clutch-brake shaft seal's
iester
04-18-2005 15:05:14
350 utility,the shaft seals seemed to have been installed reversed on this tractor.the spring on the seal is facing outward,is this correct? thanks
r4etired
04-18-2005 18:33:07
 Re: clutch-brake shaft seal's in reply to iester, 04-18-2005 15:05:14
That is supposed to be a double seal. Ih replaces them with a single.The inside one might be installed correct and because of a bad shaft the guy might have been looking for a good place on the shaft for the outside one to ride.
PAULIH300
04-18-2005 15:32:59
That doesnt sound kosher....
Sounds bass-ackwards to me.
Somebody thought the recessed backside of the seal would be a better surface to use to seat with a deepwell socket as opposed to the smooth frontside.
iester
04-18-2005 15:53:41
 Re: clutch-brake shaft seal's in reply to PAULIH300, 04-18-2005 15:32:59
yea,that's what i was thinking.I think i will put the new one's in... spring facing inward
PAULIH300
04-18-2005 16:11:16
 Re: clutch-brake shaft seal's in reply to iester, 04-18-2005 15:53:41
Maybe they were afraid the spring would pop loose and go inside? (of course it would just hang on the shaft...until the shaft was removed,and it would then hit bottom).
