A super H with a miss
Mike Lovelace
04-18-2005 16:37:23
I have tried about everything, but I"m still having a problem with one cylinder not getting a strong spark. new coil, points, cap, wires, ETC. It runs good for about a min or two and starts to miss on that cylinder. The valves are good and the cam is too. It has ran good in the past. Points are set at .020 & plugs at .023.
Delbert
04-18-2005 18:00:20
 Re: A super H with a miss in reply to Mike Lovelace, 04-18-2005 16:37:23
Are you using champion plugs? I have a super h that i put new champion plugs in and it started to miss after only a short time put one of the old plugs back in runs fine no more miss. So you my have a bad plug even if they are new. a c or autolite plugs work better in older farmall tractors. Or they used to.
Sloroll
04-18-2005 16:42:20
You couild have a valve sticking or a possible intake gasket leak, head gasket leak possible too. What does the plug look like? Is it sooted up or grey dry?
Mike Lovelace
04-18-2005 16:51:57
 Re: A super H with a miss in reply to Sloroll, 04-18-2005 16:42:20
The plug is wet.
jayw
04-18-2005 18:10:18
 Re: A super H with a miss in reply to Mike Lovelace, 04-18-2005 16:51:57
What type of plug are you using. Switch that plug with another clyinder and see if the miss follows that plug. Ive had bad Champion plugs right out of the box now use only AC
Sloroll
04-18-2005 18:31:13
 Re: A super H with a miss in reply to jayw, 04-18-2005 18:10:18
Could be a bad ring too if the plug is oily wet. Had an f-20 years ago would act like that.
