Mounting Bracket for Rear Light
Charles Park
04-19-2005 07:29:23
The mounting bracket for the rear light was attached to the light but broken off. I have no way of knowing what the other end looked like
Anyhow, I have tried to find a picture/part number of this in the Part Catalog. No luck. The light I have is much larger that the headlights. Has a yellow lens and Dietz stamped on the cover. Any ideas?
RustyFarmall
04-19-2005 08:04:04
 Re: Mounting Bracket for Rear Light in reply to Charles Park, 04-19-2005 07:29:23
The light you have is not original. It is an aftermarket, bumper mount, fog lamp to be used on an automobile. You won't find it in the parts book because it isn't there.
DWV
04-19-2005 07:42:47
What tractor light bracket is for would help someone figure it out.
Charles Park
04-19-2005 08:20:06
 Re: Mounting Bracket for Rear Light in reply to DWV, 04-19-2005 07:42:47
Sorry. It is for a Farmall M. 1944.
DWV
04-19-2005 12:00:36
 Re: Mounting Bracket for Rear Light in reply to Charles Park, 04-19-2005 08:20:06
Supports # 9231-D , 9231-DA ,353642-R1 were used.
Don't know what serial breaks are but think the 44
used cast iron support. Some H used same support.
