Order Farmall Cub Parts Online
cub clutch release bearing
ad salter
04-19-2005 09:30:11
I recently replaced the clutch plate and release bearing in my cub. When I purchased the new bearing I discovered that it really wasn't a bearing at all. Although it had a grease fitting installed, the area that contacts the pressure plate doesn't spin. From the appearance of the old parts, I noticed considerable wear on the old clutch release bearing and pressure plate where to two make contact. My super a has a regular type bearing in it and it seems to do a much better job. Is this a design flaw and is there a bearing that can be used instead of this friction type?
Bigdog
04-19-2005 10:02:55
 Re: cub clutch release bearing in reply to ad salter, 04-19-2005 09:30:11
Your cub throw out bearing is a graphite bearing. Properly lubed it will last another 40 - 50 years. If you're going to use it longer than that, there are regular bearing replacements. Some of them have been known to last as long as 6 or 7 months. Unless you enjoy splitting the tractor on a regular basis, replace the bearing with an IH replacement graphite bearing and enjoy using the tractor rather than working on it.
Cub Clutch
04-19-2005 11:08:02
 Re: cub clutch release bearing in reply to Bigdog, 04-19-2005 10:02:55
I see this repeated ad nauseum, that the ball bearing style throwout bearings don't last. Why is that?
There's nothing mystical about it. It's one of two things:
1. Bearing is made of sub-standard materials.
2. Bearing is being installed improperly, i.e. I've heard that it comes dry, and that people are installing them that way.
In the case of #1, okay, that's understandable.
If it's #2, then it's your own fault for not greasing the bearing, right?
Jim Becker
04-19-2005 16:35:22
 Re: cub clutch release bearing in reply to Cub Clutch, 04-19-2005 11:08:02
1. There have definitely been some #1. At least one of the sellers reported having to get a whole batch replaced. Some of them were reported to have not been made with thrust bearings, so of course they wouldn't last.
2. I haven't had one in my own hands but I was under the impression they were made with sealed bearings, which makes dry bearings another #1, at least in some cases.
3. The carrier for the Cub throwout bearing does not run on the shaft but is suspended from a pivot point high in the bell housing. Thus the bearing will move in an arc and it is impossible for it to remain concentric with the spinning pressure plate. Thus there will be movement of the bearing face against the fingers. Bottom line, the clutch mechanism was designed for a carbon block bearing and a ball bearing with a hard face doesn't belong there.
