Belly Pump Dipstick for M
Minnesota Marv
04-19-2005 10:50:15
Are the belly pumps on the M and the H the same? I'm wondering because I'd like to make a dipstick for my M. My neighbor has an H and if they are the same, I could use his for a model.
Marv Gustafson
The way I do it.
04-19-2005 18:01:19
 Re: Belly Pump Dipstick for M in reply to Minnesota Marv, 04-19-2005 10:50:15
Drain oil pour in 5 quarts check and mark stick quart low pour in one more quart and mark stick full. Like others said it is not that critical but if it is too low it will starve pump and if it is way overfilled it will overflow at fill cao vent.
DWV
04-19-2005 11:37:59
They are the same,if remote control valve is used
its different than without remote.If both have remote control valve they are same.
Nebraska Cowman
04-19-2005 10:54:18
no, I don't think they are the same but they will work. the level isn't that fussy. I find dipsticks in old SP combines and they work too. And the original dipsticks have been lost and replaced until who knows which one is "correct" Your neighbor might even have an M dipstick in his H
