Smta head bolt???
Todd L
04-19-2005 16:03:35
I was torking the head bolts and pulled the threads out of the block. I had the tork wrench set on 100ft. lbs. just like the book says. Now what do I do guys? This is enough to make a guy want to scream. Thanks for any help.
MagMan
04-20-2005 11:15:18
 Re: Smta head bolt??? in reply to Todd L, 04-19-2005 16:03:35
My ? is why the heck did it do that. Was the stud not all the way in the block? Did it already have a bad helicoil? Is your torque wrench Bad. I think I would try to figure out why before you just go ahead with the fix incase its going to happen again to another one.
captaink
04-20-2005 06:37:15
Even as frustrating as it is, I figure it’s better to pull the threads now and fix it than have them pull later when you are using it. Heli-coil will work fine.
El Toro
04-20-2005 05:04:55
As Wardner has suggested a helicoil will make it strong as the original threads. We used them a lot in aluminum and keenserts too. Hal
Todd L
04-20-2005 05:12:06
 Re: Smta head bolt??? in reply to El Toro, 04-20-2005 05:04:55
Thanks El Toro I have never used a helicoil before but I'll try it.
Wardner
04-19-2005 22:54:33
Sounds like you will have to install a Heli-coil. YOu will neeed a drill or endmill and the special tap. A good hardware store can set you up. I have a magnetic based drill and that is what I would use due to the size of the hole and the importance of getting a straight hole.
Todd L
04-20-2005 04:54:13
 Re: Smta head bolt??? in reply to Wardner, 04-19-2005 22:54:33
Thanks Wardner I'll look into that.
