International / Harvester dealer?
Chris in Lakefi
04-19-2005 16:52:07
Does any one know if there is a International/Havester dealer in Ontario, Canada? Any info would be greatly appreciated. Just recently bought a Loboy 185 and cant get it running! Where is the starter?
Also any info on figuring out how old is my tractor.
B Watson
04-20-2005 07:55:33
 Re: International / Harvester dealer? in reply to Chris in Lakefield Ontari, 04-19-2005 16:52:07
there's a couple of dealers around HUB Equipment has two locations in your area, one in Port Perry the other (and better of the two) in Lindsey.
The best by far though is B. Larkin Equipment in Peterborough, that's where me and my neighbours go as the old fella who looks after parts actually seems to remember old IH equipment.
Good luck
John M
04-20-2005 03:23:52
The starter is also the generator on the 154 and 184.
El Toro
04-19-2005 19:21:15
You need to post the SN of the tractor and someone
can probably determine the year.
Follow your battery cables, one goes to ground and the other to the starter. Some tractor's have the ground on the starter too and the other
cable may connect to a solenoid on the starter.
That is where battery voltage is supplied to your
starter. Will the engine crank using the starter? The battery may need charging or replaced. Hal
George 2
04-19-2005 18:05:12
You are best off to deal with Richards in Stouffville, Ontario if you are from Lakefield. They do a lot of work with older IH stuff and specialize a bit in old IH parts. Another dealer you could deal with is HUB in Lindsay and Brooklin. They are an old line dealer also but I don't know much about them.
Jeff In Ontario
04-20-2005 06:28:20
 Re: International / Harvester dealer? in reply to George 2, 04-19-2005 18:05:12
I agree with George..Richards is a great place to deal-they really know their stuff.
Jeff
Michael Soldan
04-19-2005 17:18:52
Vincent farm Equipment...Exeter, Seaforth, dealer down at New Hamburg west of kitchener...likely a list of dealers for Ontario
Yugrotcart
04-19-2005 16:56:12
Lots of IH/Case dealers around. I deal with Ed Stewarts Equipment in Erin, been in business forever. Also Stoltz Equipment, offices in Elmira,Listowel and Mildmay.
Yugrotcart
04-19-2005 16:56:06
