knock in engine 300 utility HELP??
Amishbob
04-20-2005 08:26:48
Well my worst nightmare is realized!A knock noise sounds like a rod started this morning after about 20 minutes working,oil pressure is good everything works ok but still a steady knock,I wonder could it be carbon on pistons let loose or should I just start tearing it down and check it out?? any ideas really appreciated Thanks Bob,,,
W30
04-20-2005 17:57:11
 Re: knock in engine 300 utility HELP?? in reply to Amishbob, 04-20-2005 08:26:48
Check choke butter fly in carb to see if a screw is missing, had a SM with a screw imbedded in piston that caused an awfull knock
Bob M
04-20-2005 10:27:45
Bob - A failing camshaft gear can cause an ominous knocking also. It's not uncommon on these engines on account of the live hydraulic pump being driven off the cam gear. (I have replaced several over the years...)
If the knocking sound changes or disappears when you load the live hydraulic pump, a busted cam gear is the culprit.
captaink
04-20-2005 09:23:34
If you hear the knock all the time when the engine is running, you can sometimes diagnose if it is a rod bearing by pulling off or shorting out one spark plug wire at a time and see if the knocking sound lessens on any one cylinder. If so it’s probably either the wrist pin or the rod bearing. Next, I’d pull the oil out, and see if there is any bearing material in the bottom of the pan or on the drain plug. If so, pull the pan and check the bearings as others have advised.
If the knock is most noticeable with no load on the engine and is affected by two adjoining cylinders, then it probably is a main bearing and you will need to pull the pan and check the bearings.
Something else that it could possibly be is the flywheel bolts coming loose. This can make a rhythmic knocking noise also, but usually this will go away when the clutch is pushed in.
Hope this helps…
Sloroll
04-20-2005 09:22:39
Not to panic yet. Those 300U pans fit tight. With a little wear the crank will shift fore and aft allowing the rods to strike the pan. It is pretty easy to pull the pan (check for hit marks) and roll in new rod and main bearings. I've done it in the field with the plow in the furrow. I was much thinner then though and it was fun because I was play farming.
Allan in NE
04-20-2005 09:59:02
 Re: knock in engine 300 utility HELP?? in reply to Sloroll, 04-20-2005 09:22:39
What? Play farming isn't allowed?
Hmmmm, whaddam' I gonna do now? Too scrawny to be a cowboy and too dumb to play lumberjack.
'Sides, the tree removal project here in Nebraska has been completed anyway.
No, I still think I gotta go play farmer. :>)
Rainin' down there?
Allan
Sloroll
04-20-2005 10:05:10
 Re: knock in engine 300 utility HELP?? in reply to Allan in NE, 04-20-2005 09:59:02
Rained right up to the county line and stopped! Looked like heck all black and everything then POOF! It'll probably refire this afternoon. Yah, it didn't seem like playing at the time but I have been enlightened Allen. Hey gotta chopper landing!
Allan in NE
04-20-2005 08:37:39
Hi Bob,
Ouch! Darnit, didn't need that!
Carbon buildup will have more of a "rap" sound. If your noise has a deep, "thud-like" sound to it, chances are it's on the bottom.
Plus, the bottom end is where the load ends up on these old rascals and they do have a tendency to wear at the bearings.
Hope ya get 'er straightened out,
Allan
Farmall43
04-20-2005 08:33:03
The easiest way is to pull the oil pan and look for debris in the bottom and then to check the rods for slop.
Amishbob
04-20-2005 10:41:15
 Re: knock in engine 300 utility HELP?? in reply to Farmall43, 04-20-2005 08:33:03
I'll try your suggestions and see if I can narrow it down and I'll keep you all posted on how it turns out thanks alot Bob,,, I hope I can find the parts I need?
Farmall43
04-20-2005 14:07:08
 Re: knock in engine 300 utility HELP?? in reply to Amishbob, 04-20-2005 10:41:15
Parts are still availible for these tractors. I am in the middle of a major on my 350U currently.
